Canon LTM Ql17 GIII Meter Issues
Scamper
6:57 AM
Hi All,
My light meter recent started acting really flakey. The needle would only move at times if I pressed the battery test button and sometimes it would work correctly if I fired off a few manual shots.
Nothing has change with the camera. I am using the 386 silver oxide cells and a converter from the small battery company.
Any thoughts?
-Hank
It is worth checking the wire connections to the battery box on the bottom of the camera. These quite often cause problems. If there has been any corrosion in the battery hole in the past, this could easily have spread itself up the wire and now be causing problems.
Kim
A little more than that. ;) It is worth having a look under the bottom plate and if need be check the resistance of the wires to the meter section under the top plate.
Kim
Scamper said:
Just take the battery out and poke around, I assume?
Darn. *grin*
I am very happy with the quality of the shots coming out of this camera. Hopefully I can keep it running.
If you get too many problems, I am not far up the road in Lincoln.
Kim
Scamper said:
Darn. *grin*
You might also wan't to check the contact in the base I have had a simular problem, Initially I thought I had bought a dud. After checking when I placed the battery in the chamber I could see that the contact was not very prominent, it was making an intermittent contact. You can take the base off and I think from memory I used a drop of super glue to stop it from moving back down when thje battery came into contact with it. Anyway worth a try.
Cheers David
