Question about Leica/film
jl-lb.ms
John A. Lever
10:20 AM
Hello - I just ordered a FED 3, and found the following on one website: "The bottom loading Leica copy requires a Leica style film leader, which is 18 to 22mm wide and 85mm long, and then curves upwards for a total length of 10 or 11 cm. WARNING there must be no sharp edges as they will catch on the shutter curtain and damage the rubber backing. "
Does this mean that I have to trim the film of a regular 35mm roll to approximate the "Leica leader", or will a regular 35mm roll work ok as-is?
thanks
John
I just re-read your question....the information about cutting the film is not inside the camera, it's on some internet site...so I take back what I said about using a long lead....My suggestion would be to ask the guy who sold you the Fed...regards, bob
jl-lb.ms said:
Does this mean that I have to trim the film of a regular 35mm roll to approximate the "Leica leader", or will a regular 35mm roll work ok as-is? thanks
John
John, go to the Leica Thread-Mount Forum and see the sticky "How to Load a Bottom feeder". It's right here on RFF.
Walker
FED3 back comes off
FED3 back comes off
On FED3 the back comes off. I have a non-working FED3.
I think the seller is saying that if you are bulk loading your own cassettes that you should make a leader like the retail box cassettes.
FED 3 is not a bottom loader. It has a removable back and is just as easy to load with normal manufactured film as any "modern" 35mm camera.
