question about rangefinder focus/calibration
carlito
3:12 AM
Bloomfield Hills, MI, USA
This is my first post to the forum although I've read a fair amount of content here. I just recently purchased a used Bessa R4A and have a question about focusing. My first roll came back looking not as sharp as I'd like. I've never used a rangefinder before so focusing was somewhat new to me. In my camera, I can align the RF patch just fine horizontally but it never seems to be quite aligned vertically. Should it be?
I have a 2nd roll in the camera now and have been reading up on DIY calibration. I've removed the hot shoe cover and have been trying to align the patch vertically while focused on infinity but I still can't seem to get it aligned. Am I missing something or doing something wrong? I'm not sure which way to turn the screw for vertical alignment but can't even tell a difference regardless of the direction it's turned.
Any help would be sincerely appreciated!
Carlito
It should focus both ways
If it bothers you, send it off to get fixed. Perhaps there is a DIY method.
Carlito
I have never seen an R4* open, but have calibrated an R3A.
There are 3 screws for different purposes. And they are not independent of each other. When you adjust vertical alignment, you will change horizontal alignment.
First, I recommend to diagnose the problem of mis-focus. Which lens were you using ? A fast 50mm wide open and close up is bound to fail on the R4*.
Then, take a lens that you know works well, and compare RF readings (i.e. horizontal alignment) with actual distance (measured with a tape measure for instance) and the setting of the lens on the focus scale. Easier to do that when the camera is on a tripod.
Where are you located ?
Roland.
Turning the vertical alignment screw (one on the right, with front of camera facing away) the RF patch doesn't seem to move either horizontally or vertically.
The camera has a 40mm lens and photos seemed slightly out of focus regardless of distance.
Unfortunately, I don't have other lenses to test with although I will try your suggestion with the one lens I have.
I'm located in Michigan, USA.
I can send you some instructions on rangefinder calibration on an R4A, but if you're not used to doing it and don't have the tools, I'd recommend sending it in to an expert. Just PM me your email address if you'd like the instructions.
