question: hp5 in d76 1:1
audible
2:18 PM
hi guys,
i've avoided d76 up till now because of the hassle of making the stock solution, but i finally gave in to curiousity. the only thing is, the massive dev chart says 13 minutes at 20 deg while ilford recommends 11 minutes.
which is it?
Ten and a half or eleven minutes in ID-11 1:1 here, that's the same stuff yes?
FWIW, I much prefer Microphen for HP5.
Hi sepiareverb,
What differences do you see the Microphen versus D76. I've been using D76 and occasionally DDX with HP5 for developing the negatives and I haven't seen a big difference between the two. Just curious,
Mike
Just came home with an exposed HP5 -a test roll on the new ZM. I think I'll try buyibg some Micrphen in this town tomorrow after work....
the massive dev chart might be useful for film/dev combos where there is no other info, but I haven't figured out why anyone would trust it over the manufacturer.
The ZM lenses seem to be made for Microphen & HP5- my rolls with this combo are quite 'sparkly'. I run HP5 @400 and in Microphen 1:1 at 70° using Ilfords 68° time.
Memory is telling me it's 12 minutes?
