Question on The Billingham Hadley Pro
dcsang
Canadian & Not A Dentist
7:23 AM
Ok.. so I got the Hadley Pro (thanks to all the comments on a recent thread) and it was local at a very reasonable price :)
I noted that it comes with two larger dividers and two smaller ones.
I honestly think I can add at least one more larger divider to split the bag up "just right" but don't know which divider I would use.
Does anyone have any suggestions?
Just to be clear, I would like three large dividers in the bag to make 4 "slots" within the main compartment.
Dave
i have a bag of extra dividers that have been collected over the years...i usually just try to find one that works...
I was thinking of that too Joe.. I wanted something as "tall" as the Billingham ones.. I hope I've got one laying around :(
Dave
Suggestion , why not get an extra insert.. Use one divider from it and save the extra insert for a different gear setup that can be used as a two-compartment setup for other gear? Just take out one insert (say for m bodies) and place the other (say for SLR gear) in the bag when you have need for a different kit?
I've used the two large dividers to make small sections on each end of the bag, just big enough to slot in a M(whatever) with short lens. At the bottom of each, I put the small square dividers in a trapdoor arrangement, so a lens can go at the bottom, and a camera can sit on top. Then the larger middle section can be used for whatever knickknacks I want to carry.
... ditto, except I have the front one full depth for all the bits ...
