I just got back from New Orleans and have 4 rolls of Tri-X 400 shot mostly at 400 iso and had some questions about developing them in Diafine. I did a search and found some information mostly from 2006. I shoot mostly street stuff and Have been shooting at 400 iso... should I be shooting it higher? and how much 800-1250?
Do I pre-wet?
How long can I use Diafine?
Should I just go by the info on the Diafine box? And what does agitate gently for 5 sec. mean?
What type of fixer should I use? Can I re-use it and for how long?
Sorry for so many questions! And thanks for your help.
Let's see, yes, generally when shooting for Diafine I rate TriX at 1250. You can rate the film at what ever speed you wish, but the "slower" you rate it the higher the contrast I believe. There are threads somewhere comparing the results shot at various ISOs.
I do not pre-wet the film.
Diafine last a while once mixed. A group of us all got our first batches at the same time. Mine never failed, but I discarded it, almost 2 years after mixing, when everyone elses mixes started to go. It just keeps going and going and going....
Agitate gently....I pour in bath one, slowly agitate for 5 to 10 seconds, bump and set the tank down. 2 1/2 or minutes later I do the same and sit her down. After 5 to 6 minutes I remove bath one and add bath 2 repeating the process. Remove bath 2 wash for 30 to 60 seconds with water and then onto the fix.
I use Kodak Rapid Fix, as I would with any developer for at least 8 minutes. I use my fix as a one off so I don't reuse it, but others do.
I would say to develop your current film as you normally would and then shot the next batch to use Diafine. Better to get the results you can trust from New Orleans and experiment on something else.
Good Luck
