AusDLK
Famous Photographer
I just developed my first roll of film using the WD2D+ Pyro-Metol developer.
I developed one roll of 35mm 400TX according the enclosed instructions. I mixed 500ml of water with 10ml of solution A and B (each).
The film was developed for 10 minutes at 68 degrees. Agitation was 15 seconds every 30 seconds.
The resulting film was very thin. I'm not sure that any of the frames will be printable. It is a test roll so I'm not concerned (yet).
I am seeking advice as to what to expect.
Should the density of the negatives be similar to what I experience with other developers?
I am going to expose another test roll to verify correct exposure but if the results are the same are there any recommended adjustments to development time?
Any experienced WD2D+ developers out there?
