Hi Back Alley,
Where can I find a canon 35/2 for less than $200? When I search ebay, I get lots of canon 35/2 but some say EF mount, some say FD mount and I'm a bit confused. Which, if either, is the one I should be looking for?
Thanks
RollingBall, I'm not Back Alley, but if you are looking for a Canon 35/2 lens for your RD1, M Leica, LTM Leica, you do not want either EF lenses (auto focusing lenses for the Canon EOS line) or FD lenses (manual focusing lenses for the canon SLR's that preceded the EOS line -- F1, FTB, etc) You want a rangefinder coupled lens.
You can narrow your search by using search criteria on the left hand side of the page.
Go to cameras, go to lenses, and then click Canon for lens brand, and Leica for camera brand, Rangefinder for Camera Type, and manual focus for Focus Type. You can then also put LTM (Leica Thread Mount) or LSM (Leica screw mount) in the search field.
As you do this more often, you will find that you don't have to specify so many parameters.
That should get you mostly correct lenses.
If you then do a similar searches but insert SLR for camera type, you will get mostly FD and EOS lenses. After you see the difference, you should be able to tell the difference visually as you go forward.
I do not think you will find a Canon 35/2 LTM for under $200.
Good luck.
Giorgio
