N
Noorderlicht
Guest
Hello everybody,
Below is the caveat I would have liked to read before buying, so here it is for what it's worth in case you're tempted by the combination. Related question comes at the bottom.
Bought the Bessa R2 and the latest Leica Summicron 2/50 for one another back in 2002, and slides have been sharp ever since, as long as I keep subjects at arm's length (literally).
Fact: below the very 0.8m notch on the lens, R2's RF lens coupler loses contact with the rear lens rim altogether.
Amounts to: basically iffy focus 1-0.8m (unless heavily stopped down, of course) and obviously none at all 0.8-0.7m (the latter being the Summicron's closeup limit). And of course, from 0.8m to 0.7m the outline in the RF patch stays frozen with respect to its main counterpart.
Your (perception of) mileage may vary, but once you get used to the sharp results the very same combination is capable of (e.g. landscape, 1/1000s f:4, Velvia 100F), the closeup problem won't go unnoticed, and that's an understatement.
Related question now: has anyone mounted a Summicron 50 on the new Bessa R3A and turned the distance ring end-to-end, outline in the RF patch offsetting accordingly all along?
If not, but combination at hand, could someone check that up for me, please?
Thanks in advance, best of light to you all!
