Sonnar Brian
A SN 1,21x,xxx is way past the use of Thorium. My two 1,04x,xxx are Thorium lenses. I keep a UV filter over the front elements. Thorium is primarily an Alpha emitter, easily blocked. Just do not ingest it, as I was told in Physics Lab.
The Summicron is the only Radioactive lens that I know of with a Thorium Front element. The 50/1.4 Super-Takumar and Canon 58/1.2 had Thorium glass for the inner elements, not front.
I used a UV lamp to cure the yellowing on the Pentax lens. The Summicron had been sun-cured before I got it, but that dried the lubricants. I disassembled the mount and relubed it. Good for Black and White, produces "wishy-Washy colors". I much prefer my 1,3xx,xxx Collapsible Summicrons for color work.
But- to answer your question, I used a Geiger Counter on a HUGE Thorium optic for a high-speed, 1.6MFPS framing camera that used a Helium-Turbine to spin a rotating mirror. It set off the Geiger Counter, but was not alarming.
