Thanks for your kind comments. Having seen the Cartier-Bresson archive I know I’ll never approach his output volume, let alone the quality of the best ones, but I can try.
I took a Leica M10 Monochrom, a Leica M11 Monochrom and 28mm and 50mm Summiluxes, and a 75mm Summicron that I didn’t end up using. I also took a Pentax K-3 iii Monochrome with 15, 21, 35 and 70mm HD lenses as backup, but only ended up using it when all my Leica batteries (M11x2 and M10x3) were flat. I had yellow and red filters for the lenses. I only used the yellow a few times. I also took my iPhone.
Of the photos that you see here, the normal angle ones are taken with the 50 Summilux and the wide ones are taken with the 28 Summilux. At web sizes there is no functional difference between photos from the M10 and M11. One photo I’ll post later is from the Pentax. They are minimally processed using Lightroom, mostly just a little mask selection and dodging/burning. Pretty much the same as I’d have done in the darkroom with film photos.
I don’t really think too much about gear anymore, I mostly think about taking photos.
