Rangefinder vs Electronic viewfinder
thjk
5:47 AM
Bangkok, Thailand
I just notice it when I use EVF 2 on my M-P 240. At the same time when the EVF2 is in-focus (picture will also come out well focused and sharp), I notice that the picture view finder is not in-focus. And whenever I make the viewfinder in-focus, the picture will come out blurred. I am now using 50mm summilux asph lens.
I am not sure this come from my eyes' problem or camera's?
Sounds like a rangefinder calibration or a lens calibration problem from your description. Just to confirm, do you mean that when the rangefinder images are not aligned, but the EVF is in focus the resulting image is properly focused? And when the rangefinder images are aligned (and therefore supposedly the lens is properly focused) the image is out of focus? If so that is definitely a camera rangefinder adjustment issue or a lens adjustment issue. (An out of adjustment lens would still focus accurately with the EVF as the EVF relies purely on the image through the lens not the mechanical alignment of the lenses focusing mechanism which only affects the rangefinder.)
The Summilux 50 asph is known for focus issues due to the complexity of the floating element mechanism. Send it in, preferably together with the body.
