Ok, so here we are. First day with the Firstflex 35.
Pentacon 3.5/30 mounted:
Pentacon 3.5/30 on Firstflex 36 by
Berang Berang, on Flickr
Fits just fine. I have to imagine that the Tokinon lens's one-way compatibility was probably planned. Exakta lenses, and T-mount lenses could be mounted on the Firstflex, but Firstflex lenses can't be mounted on Exas/Exaktas.
Firstflex 35 shutter by
The shutter works just like the shutter in an Exa. The mirror swings up, and is followed by a capping section, which then fits against the back of the mirror sealing light out. Only in this case, both swing back down automatically.
Then it was time to do some cleaning:
In pieces by
The viewfinder was filthy with haze and specks. The exposure counter didn't work. The viewfinder was easy to take care of. I just had to clean all the crumbling foam out of the pentaprism housing. I replaced it with strip of packing foam for now. Blew out the focusing screen and cleaned the pentaprism's glass surfaces and the eyepiece.
The exposure counter doesn't seem to be repairable. There is too much "slop" (for lack of a better term) and no apparent way to adjust it out, not even in the primitive Exa way of just bending the linkage until play is removed.
Tokinon 2.8/45 lens. by
Lens was quite fiddly. It is a front element focus Tessar (I think? the rear element is pretty thick if it's only a single element). Somebody had absolutely wrenched the front off, pulling one of the stop screws out. But I got it cleaned up and put back together.
Frustratingly this lens also won't fit on my Exakta-Canon adapter. But it will fit on an Exakta extension tube, which can then be fitted to the adapter! So I took some close up photos with the thing.
Tokinon 2.8/45 test by
tokinon 2.8/45 test by
Not too bad for what is either a three or four element lens shot wide open!
Sparkly boke' quality:
tokinon 2.8/45 boke by
I'll be running a roll through as soon as time permits.
