raw+jpeg
PhilReaston
3:33 PM
Hi all: My first post so be gentle :eek:
I just got an R-D1 from another RFF member. I've been trying to get it to shoot Raw+Jpeg, but all I get is the raw file. I assume I should be getting a jpeg too - If I'm wrong there let me know.
I have the Raw setting in the settings menu set to Raw+Jpeg and I have the quality on the analog dial set to Raw. Is there something else I need to do to get the jpeg too? I did try a couple of different SD cards on the off chance that might be the problem. Also, I changed the Film setting from Film1 to Standard.
I searched the forum and found one reference to this from someone who reported the same issue. He also reported a few posts later that it was now working correctly, but wasn't sure why.
Any ideas?
Same thing happened to me...
it wouldn't work at first, then started working for no reason I could figure, and has worked perfectly since.
I did find, though, that the buffer fills quickly in the double mode, and so I went back to shooting RAW only.
Sorry this isn't more helpful--I'll be curious if someone has an actual explanation.
Sanjay
Ok. This is wierd. I just tried this again and now it works. When I checked the settings menu it was back at just Raw rather than Raw + jpeg. So it looks like operator error - although I went round this a few times.
I'd guess there's a minor software bug.
I'm glad it started working for you too.
Sanjay
