Re-lubing I-50 Instructions
fgianni
Trainee Amateur
1:48 PM
I have an I-50 in LTM that will need re-lubing, is anyone aware of step by step insructions on how to do that?
Thanks
If the J9 isn't in the post, send that as well.
Kim
Thanks
Kim
Thank you for your very kind offer, however the J9 is already in the post with a cheque for the CV 50mm Nokton; also I am quite new to this rangefinder business (bught my firt RF camera last July) but I think part of the fun is to be able to do some basic servicing on your equipment.
And what better lens to start with than an inexpensive I-50? Even if I damage it it won't be a big loss.
Since you are in the UK like me you might be able to answer a couple of questions:
What kind of polish available in the UK would you recommend for the chrome?
And what grease for lubricating it?
Thanks
Guys thanks a lot for the links, it looks a task that even I should be able to complete successfully (when it comes to DIY I have 2 left hands)
The grease I use comes from work. It is a red aviation grade grease called Mobilgrease 28. I can easily send a small tub down. You need a fully synthetic grease which is not too thick and doesn't "bleed" any oil out of it. A good test is to put a "dollup" of the stuff on a piece of paper and leave it for 24 hours or so. The dollup shouldn'y loose it's shape or cause a large oil stain on the paper. There isn't a lot of chrome on the FSU lenses, it's aluminium and most have been coated with a laquer. If most of this has gone, you have nothing to lose but otherwise I would just give it a good clean if need be with some Cif cream. If you do polish any good metal polish like Silvo or car chrome cleaner works well.
Kim
Thanks
