Red window question
garyc
3:01 PM
Southampton, UK
Just acquired an Agfa Isolette III which has a red window + cover slider instead of a counter. Question: is colour/chromagenic film any more sensitive to fogging due to any stray red light than b&w? I presume the slider is only meant to be flipped open for a few seconds while the film is wound, but should I be worried about leaks during this time?
I've used a Kodak TLR Reflex with ASA 200 Kodacolor film. It has the same type covered red window as yours. I did not notice any light leaks on the exposed film.
Many cameras with that red window don't even have a cover. My old Brownie Starflash didn't have one. Many people used Kodacolor or Ektachrome in those and never fogged it that way. I remember a friend's camera that didn't even have a colored lens in it, just a small opening to the yellow backing paper.
I also vaguely remember one of my dad's cameras having a green, as opposed to red window.
If you look at the backing paper, you will see that it's VERY opaque. I don't think that window is gonna fog the film very easily.
I did have this red-spot problem with 220 color film in my Ansco Viking 6x9. A big red spot appeared on many of the shots (I think after the paper ceased to cover the film).
C.
C.
It is my belief that 220 film does NOT have a paper backing, therefore it would be subject to fogging whither it be Color film or B&W film.
Wayne
Yeah, 220 film has paper only at each end of the film--to keep it light tight while loading or un-loading. This is why twice as much film is only a little bigger around. I've never had a problem with any 120 film fogging but I try to keep the window out of direct sun as much as possible just to minimize the chance of any light leaks.
Rob
