peterm1
Oh, and I also would like to ask if anyone knows how do I polish the outside of the lens? It has some blemishes on the metal that I'd like to remove.
I do not need to polish it to look like new, just a bit of hygienic touch up or so.
I very much like the stuff in the picture. It has cotton wadding soaked in a mild metal polish (it smells like and most probably is "Brasso" as its known in Australia) . It is usually sold in auto parts stores. I have used it a number of times to clean up the chrome on various lenses and it is good for getting rid of mild discoloration or oxidization. If something stronger or more robust is needed when there is more corrosion,the same stores will usually have tubes of chrome polish paste designed for car chrome - which works also but the cotton wadding solution is easier to handle and there is less chance of getting paste residue in places it should not go.
If you own a dremel tool or similar you can also use the little polishing buffers made from compressed felt and a little paste polish to clean stubborn spots. But dremel tools rotate at an ungodly speed so you need to be careful not to overdo it.
