colyn
ישו משיח
I have a Retina parts camera coming in that I want to use the leatherette from. The original was glued using shellac and for the most part is easy to remove. However there is usually a hard to remove area which usually results in damage to the leatherette.
What is an easy way to loosen the shellac so the entire piece can be removed without damaging it??
