Repairing Canon Serenar 85mm f2
Roel
11:07 PM
I have a beautiful (and heavy) Canon Serenar 85mm f2. The aperture ring is a bit stuck and i see big flakes of stuf lying on the aperture blades. Looks like coating from the barrel.
Anybody know how to open up the lens to have a better look? Is it difficult for this model. Maybe even a link available?
Would like try the lens on my Leica Monochrome.
Hi Ferider,
just tried but nothing gives any motion and i am not exactly sure which frontpart you mean. I am afraid to break something. Also should i open it clockwise or the other direction.
Grab the entire front part including aperture ring and turn counter clock wise. I only have pictures for the Nikkor 85/2, but I have cleaned the (chrome) Canon 85/2 as well, and it was similar. Here you can see how I did it for the Nikkor lens:
http://ferider.smugmug.com/Technical/Lenses/Nikkor-852-CLA
Then you can access the rear part of the lens and uncrew that to see the aperture.
Here you can see a picture of the disassembled Canon 85/1.9 (almost the same lens as yours):
http://www.rangefinderforum.com/forums/showthread.php?t=123081
Roland.
Thnx Roland,
This is very helpful! So no screws to loosen first. Only thing is that if I grab the frontpart including aperture the whole thing still doesn't move a bit. Maybe I should eat some energy bars and try again. It's so fixed i am afraid to damage the whole thing by applying even more pressure.
Will try again later.
Are the "big flakes of stuff" black in color? If so its the black paint from the inside of the lens - applied during manufacture to reduce internal reflections. Its pretty common with some older lenses in fact and is nothing much to worry about as it is easily rectified.
Yes the big flakes are black/dark greyish and look like paint. Even seem to have some curve.
But first I have to open up the lens..
Flakes
Flakes
Use something rubber to give you a better grip. Clean work gloves with rubberized palms, a piece cut from an old bicycle inner tube, the kind of rubber mats intended to help open jars etc. When you try this bare-handed, you can squeeze till your knuckles go white but you can't apply very much twisting force at all.
The 85mm f2.0 Serena lens head does not simply unscrew. The f1.9 does, but not the f2.0. There are three set screws on the focusing ring. Perhaps removing them would free the lens head.
I managed to unscrew the front part and get out all of the paint chips. The inside of the barrel between the apperture blades and the front lens part looked perfect. So I wonder where the paint comes from. Could it be that the paint is from the glass? The bevel of the glass is clear without paint. Does anybody know if this should be painted?
[/url]Canon Serenar 85mm f2 by RoelvanNoord, on Flickr[/IMG]
