Resetting frame counter in Bessa R
sooner
3:02 AM
Hi Folks,
I bought the Bessa R and 35mm 2.5 skopar deal from Stephen recently, and loved the camera immediately. But after shooting my first roll of film--a 24 count--I loaded up my second roll and found the frame counter did not reset. Now I'm going past the 36 with half a roll left. What did I do wrong so the film counter failed to reset? Also, is it a problem to keep shooting past the 36, like is that going to cause problems? Any guidance would be appreciated here.
Thanks. --John
Bang it a bit (literally but not too hard). Sometimes it does stick a bit.
You should also check the door because the trick to self resetting film counters is a pin on the door which disengages when you open it to reload. The pin/switch is located in the upper right part of the light trap groove. Check if the switch moves smoothly, if not you may have a broken spring. Also try to prick it with some kind of toothpick stuff.
Hope it helps.
Thanks for the suggestions, I'll try to find and engage the switch myself, failing that I'll contact SG.
