eli griggs
How many here have and use a Ricoh 35 zf? I've one of these little cameras and despite the non-working meter and the 'B' setting not closing when tripped until I change the speed setting or advance the film, a result of a do it yourself lens cleaning adventure, seems like a nice little camera.
I've not yet run film through this camera, partly because i forgot it was in the house, partly because I did not have until this last few weeks a complete enough darkroom setup to check out film results.
From what I see this camera is well liked elsewhere and I'd like to hear other opinions on it in general.
By-the-way, if anyone knows where on the web I can view schematics of the 35 zf, so I can try to put the 'B' setting and the meter right, I'd sure appreciate a link or any guidance at all.
Cheers
[/SIZE][/SIZE]
Cheers
[/SIZE][/SIZE]
eaglit
Ricoh 35 zf
I have one of these and it seems to work fine. I have read that it does not work without a battery ( the shutter speed will not change) but when I run it through the shutter speeds without the battery it seems to work. You can check out some pictures I took with it at http://www.flickr.com/photos/84236321@N00/276338149/. Good luck and let me know how it works out.
ChrisPlatt
Thread Killer
IIRC the 500ZF is just like a Ricoh 500G, without
a rangefinder. It's a very pleasant small camera.
The 40mm f/2.8 lens is a very good performer.
This camera offers two exposure modes; metered
manual and shutter priority AE with exposure lock.
It was designed to use a PX675 1.3V mercury battery.
Adjust film speed setting, use Wein cell, or have it
recalibrated to use a 1.5V silver cell (SR44/357/MS76, etc.).
The shutter is mechanical and should work at all
speeds including B without a battery.
Foam light seals are often ugly on these but they
are easy to replace yourself at very modest cost.
"Excelsior, you fathead!"
-Chris-
-Chris-
eli griggs
Thanks guys for the info. I was beginning to believe no one here would 'own up' to having one of these neat little cameras.
Chris, I'll take a look and see if I can find the schematics for the 500g and see if it helps with the lens repair. I also guess I should take a closer look at the meter and battery compartment and see if there's anything I can do there. Even though I'm fine with a stand alone meter, it's always good to have a working meter in camera.
Eglet, I enjoyed your photographs. It's nice to see the subtle quality of color work with this camera; well done. Did you use the camera meter?
I'll post pics when I can.
Cheers
Cheers
Roman Siberia
1.5v
1.5v
Hello, Chris!
Can you please explain, how 35 ZF can be calibrated to usage with 1.5V batteries. I suppose the way is to change film speed, but to increase or decrease?
Thanks and cheers from Siberia!
1.5v
Hello, Chris!
