TimSmith-Laing
Hi guys,
Am having a developer holiday and I'd like some advice. Normally I stick to my trusty ilfosol 3 - which seems to have few fans here, but which is easy to get hold of and easy to use - but I decided to pick up some Rodinal and have a play.
So, recommendations for Acros and Foma?
The Foma is @ EI50. The massive dev chart gives Foma @EI100 as 1:19, 6.5 mins, so I was going to have a crack at 5.5 mins - which is the time I use for EI50 in Ilfosol, at 20 deg.c. Thoughts?
The Acros is box-speed. Massive dev chart gives 1:50, 13.5 mins. Again. thoughts?
I hear a lot about stand development with Rodinal, and I'm not sure I have the patience for it, but I'm willing to give it a crack if it's really the best way of getting good results.
I also get the impression that Rodinal can be kinda touchy with agitation and grain, hence people's preference for stand dev. My normal routine is gentle inversions for first 30 secs, then 10 secs every minute after that. How'll that work with Rodinal?
Cheers in advance,
Tim
Cheers in advance,
Tim
