Rokkor 28/2.8M on M9
raid
Dad Photographer
9:24 AM
I would like to learn about your experiences with the Minolta Rokkor 28mm 2.8 on the M9. I took my Rokkor out of "retirement" yesterday, and I am trying to get a feel for using it with the M9. Has anyone observed problems? I recall from online reports on the Rokkor with film cameras that this little lens was well received, as compared with the Elmarit. I hope that being a 28mm lens, its coverage is still acceptable on an M9 to be free of strong distortion levels. My example may have a small number of white spots, but there are few, and it may be multi-coated. The serial number is written on the lens barrel and not the lens front.
Thanks for your input here.
I will today again use this lens to get some images that I can inspect. If I like what I see, I may make it the main wide angle lens in the next trip.
If you are talking about the CLE 28/2.8, don't know on the M9, but on the 240 it's one of my favorites. Small, sharp, no Italian Flag. Coded as Elmarit-M 28mm f/2.8 (IV) / 11809.
I have a CLE lens 28/2.8. I am glad that you find it to be an excellent performer. I code it as a 28/2.8 in the M9.
Why code as a Leica 28mm f2.8. Isn't that going to invoke software lens correction that is not appropriate.
Here are some snapshots with this lens.
link: https://raid.smugmug.com/Rokkor-M-28mm-28-M9/
Looks, good, Raid! I don't see any "italian flag" edge coloring. Just a few dirt spots on the sensor. ;)
Thanks, Doug. I need again to clean the sensor! Maybe I will leave the sensor alone. A few dirt spots can be taken care of with PF, as needed. The cleaning process can move dirt spots around even worse.
I took at sunset some photos wide open with the lens. I will inspect them. I will also use the lens tomorrow wide open. Have you seen your lens give mushy looking OOF areas when used wide open?
I really don't know. I just take the photos without dwelling on frame lines as I can see the results and then I make corrections.
