Rokkor M mount lens compatibility with other M mount cameras
The head bartender here has some good Minolta CL / CLE and Rokkor information here on his Cameraquest site:
https://www.cameraquest.com/cle.htm
I don't own the Rokkor / Zeiss Ikon combination, so I don’t have firsthand experience, but I cannot recall anyone on this site reporting having issues. Both companies use the Leica M standard as far as I know.
The 40mm lens for the CL (not CLE) lenses had a more steeply sloped RF coupling cam than other M-series lenses. This wouldn't have made a difference on a perfectly-set-up camera, but a given amount of angular error would produce more focusing error with a CL lens than a regular lens. There was a lot of discussion of this back in the day, but most likely the forgiving DOF of a 40mm lens prevented it from being a real-world problem. I don’t remember if the 90mm cam was the same way or not.
The only MR lens which is somewhat worthy now is 40/2. 90 is nothing special, 28 is self-generator of spots.
I would skip entire MR line now. Not worth it on any other than Minolta cameras. IMO.
Owning both the 28/2.8 and 90/4 I've had no issues with using the rokkor lenses with any of my M bodies (Even though my 90 is the made in Germany by leitz version)
