Rollei LTM Rollei 40mm f2.8 HFT Sonnar
Rollei M39 screw mount lenses
This is the Sonnar sold with the Rollei RF correct. Huck Finn has one and is very impressed with it.
I have a pdf of the Rollei RF system- can't post a pdf it seems, but I will quote:
"Sonnar 40mm f/2.8 HFT
The famous candid lens of the legendary Rollei 35S. The ideal focal length for indoors and out. A lens ideally suited for news photography. Its initial aperture of f/2.8 gives it a wide margin for shooting in low light with excellent results.
FIlter thread: M 39
Specs:
Aperture range: f/2.8 - f/22
angle of view, diagonal/horizontal: 54.9°/46.8°
optical system: 5 elements/4 components
focusing: 0.7 m - infinity
diameter: 51 mm
length: 30.5 mm (w/o lens hood)
weight: approx. 175 g
filter size: E 39"
I can send you the pdf of the whole brochure (2.1 MB) or just the lens info trimmed out of it (180 KB).
WIll have to be tomorrow afternoon, I've got to get packed for tomorrows sunny day!
added- I haven't shot with this lens, longed for it, but have the hood & VF for my 40 'cron (the 'cron was cheaper). They are the CV pieces I believe- and are quite nice. The VF is bright, the hood metal and extremely nicely finished.
i wonder about it on an r4, a kit with 25 & 40, using the 35 fl. but i would only be interested if the sonnar 'look' was prevalent.
joe
It is a recent purchase and I haven't had a chance to scan any negs from the 1 roll of film I've put through it.
i just found a bunch of info on the lens. i didn't realize it was the lens from the cosina built rollei 35.
but i still have not read much about it's sonnar look (or not).
there are 40mm summicrons and rokkors aplenty if one just wanted the 40 fov and petite size.
I've got one that came with the "kit"...Rollei 35RF w/40mm Sonnar. Coming from SLR (old Pentax mf stuff), it and the Zeiss Biogon 25 that I picked up at the time both offer very noticible improvement in color, contrast and clarity. There are those who say it's a little soft, but I haven't noticed that.
I have the Sonnar with the Rollei 35RF. I really like it. Mechanics are very smooth. Nice weight. Nice size. Seems sharp with good color.
Bare in mind that my only other RF lenses are the Heliar and Ultron, and that I'm new to the RF world. Having shot SLR for about 25 years and counting.
I have several shots taken with the Sonnar on my Flickr photo stream.
The ones tagged with "Sonnar" are here:
http://flickr.com/search/?w=48421455%40N00&q=sonnar&m=text
Some of my shots w/the Rollei 40/2.8 (have some more recent shots, but haven't gotten around to doing post & uploading them):
http://www.flickr.com/photos/tags/rollei4028sonnar/
It's a fine lens, but I don't think the Sonnar signature comes through that much because it's only an f/2.8 lens. I wish Rollei had not been so committed to recreating their old designs w/their 35RF lenses & produced a 40/2.
This is a superb lens in every way. The Sonnar look comes through when shooting wide open - although not to the same degree as f/1.5. More of a look that is not razor sharp with a little softening in the corners. Stopped down it is quite sharp. Build quality is also superb; it is one of the few modern lenses you'll find that is actually made of brass. Comes with a Leica-style tab.
What I like best about pictures taken with this lens are color & tonality plus the fact that it just does not flare. As a walk around lens, it is very compact & is fast enough for almost any situation you'll encounter.
One advantage that it has over other 40's is that it is easily adapted to 35 mm frame lines because it is LTM. If you want to bring up 35 FLs instead of 50, just change the adapter. It works quite well with the 35 frame lines on my ZI.
At its current price, I compare its position in the current Zeiss M-line to the 50/2.8 Elmarit in the Leica line-up. it's the cheapest Zeiss design currently available for an M-mount camera.
H'mmmm. So, in your opinion, Huck, this lens, with a 35mm adapter, should work well with the M8 with the 35mm framelines?
