Dan Daniel
OK, so I have had a mirror installed in a Rolleiflex T crack. Twice now. Obviously something is wrong.
I've done dozens of mirrors is TLRs and never had this problem. The only thing that is different about this T is that the flat brass spring part that goes behind the mirror has two thin tabs at the bottom edge. It seemed to go in fine, maybe a little sense of tightness when tightening the two screws that hold the side tabs in. Since one of the mirrors cracked at the tabs, I guess that's a problem point.
Mirrors are cut fine, not oversized, etc.
Thoughts? Should I cut off the bottom tabs? Throw out the spring and use foam as cushion/spring?
