RTS II & Sigma 21-35 lens
ThreeToedSlothLuke
8:45 PM
I picked up a cheap Sigma 21-35 in C/Y mount but when I mount it on my RTS II the camera shows f2 at the widest aperture and not the f3.5 that is on the lens.
I realize this may just be "how it is" and I should stick to manual exposure (I generally prefer the AE) but I thought I'd ask just in case I'm doing something wrong here.
Colin
I don't know anything about the RTS II, but it may not be able to show f/3.5. Have you checked the user's manual?
I sure envy you the lens. Sigma never seemed to get the credit I thought is deserved for its lens line. I used to have a 600mm cat and absolutely loved it. I now have a 200mm and macro that is really fun to use.
This is a not-so-rare problem that occurs on C/Y lenses and Contax cameras. I've encountered a similar problem on my C/Y Zeiss 28mm F/2.8 The mechanical linkage communicating the aperture value to the camera is off. If your other C/Y lenses have no such issue on your RTS II, most likely the lens is to blame.
It can be fixed. But it is also not a big deal. This will affect the aperture-priory mode because the metering will be off. But for manual operation and metering there won't be any problem.
...The mechanical linkage communicating the aperture value to the camera is off. If your other C/Y lenses have no such issue on your RTS II, most likely the lens is to blame.
Thanks. As the Planar 1.7 has no problems I'll just use my meter or sunny 16 with this Sigma lens.
