Rumination on Jupiter 3 to Leica standard (51.4mm) modification
TenEleven
5:08 PM
This is sort of a trip report/blog/rumination on my attempt to modify a cheaply bought Jupiter 3 to the LTM standard.
I got a Jupiter 3, for a measly ~$85 locally. For such a low price you are going to assume that the lens had its share of problems -- and you would be right. Upon first inspection the helicoid was so frozen that any attempt to focus unscrewed the lens. The aperture adjustments too slick, the blades covered in oil and the lens hazy throughout.
So I disassembled and CLA'd the lens. Since this is standard procedure I'm not going to detail it here. However, the lens cleaned up nicely. With the exception of the main-shim, which was laughably off - infinity could not be reached until f/5.6.
Since the mechanics and glass were both very nice and the lens was very sharp on my NEX-5, I decided it was a good candidate for the modifications Brian so generously detailed here.
Using my crude tools (don't have a workshop & locked-down) I slowly filed and sanded the rear mount of the lens down until it agreed with a known good Leica M2 at all focus distances. I used a ground glass taped to the film rail, viewing with the lens wide open through a 42x magnifier to verify focus at infinity, 3m and 1m. This required some back and forth but eventually I got there.
According to my calipers I sanded off about 0.8mm.
Next I adjusted the main shim for good infinity focus at f/1.5. And re-tapped the aperture index so it would line up. This was my first mistake, but read on.
After all this I tested the lens on film using the same Leica M2 camera with a Leitz M/L adapter. (Personally after a lot of bad experiences I'd recommend against off-brand M/L adapters.) The results showed a lens that had amazing performance at f/1.5 and followed the rangefinder spot faithfully until the closest focus distance was reached.
This all seems "too good to be true" because that's some amazing performance from this old Russian lens. And sadly it was. Stopped down it was another story entirely:
I tried to re-calibrate the main shim, leaving the inter-lens distance the same since focus seemed to follow the RF fine already. I also redid the aperture index, which after several re-doings wouldn't hold its grub screws anymore. For now I've taped it in place since this is likely not the last adjustment it will go through.
None the less, the result was ... well .. let's say .. humorous amounts of focus shift:
Now, I can hear you say: "But Manuel, that's just how Sonnars work. Focus shift is a fact of life!"
Well, maybe on a digital camera. But on fine-grain film, so far I've never had any issues whatsoever.
To prove this point here's my 2859xxx LTM 'T' wartime Sonnar that is somehow uncoated(!?). (Note to Brian: This lens will eventually get a thread of it's own together with other "weird" Zeiss Sonnars I have.) It is very close and representative to my other LTM/Contax Sonnars in its behavior.
Note that the thin veil disappears as you stop down a bit beyond f/1.5, but the focal point stays exactly at the RF indicated position. Nice!
I have omitted the closest focal distance to avoid overloading the thread. Truth be told I've also shaken the camera at the f/2.8 setting. Anyway, the story is much the same as the other two focal distances:
Does have anyone any thoughts on this? Is the Jupiter 3 focus-shift a given? Should I just save the various lens elements to "rescue" other lenses?
Is my Jupiter 3 just a bad apple? Are Jupiters more prone to focus-shift?
PS: I tested the Jupiter-3+ from Lomography and perhaps unsurprisingly it has similar, perhaps less extreme, behavior to its older brother. I still like that lens though. It still exhibits strong focus shift VS the original Sonnar types, however.
This looks like a really good/late KMZ J-3 to me.
Remember that reducing the distance between front/rear groups lowers the actual focal, but it is not 1:1. Use the lens-makers formula, you need to reduce it about 2mm or so. You've gotten it very close, and the results look good to me.
The Wartime Sonnars are amazing- only the C-Sonnar, much larger elements, is sharper- and not by much.
I look forward to seeing your collection of Sonnars. I've not forgotten about doing an article on them, just insanely busy with work.
Hey Brian, thanks for your reply. I really appreciate it. I guess I will try to play with the main-shim some more to find a "sweet" spot for it.
And yes focus shift aside I'm *very* impressed with this J3. It beats the pants off the Lomography J3+ optically, although the J3+ is a bit better behaved focus wise.
[Nerd Digression Follows]
Regarding LTM Sonnars, have you seen the post-war LTM Jena Sonnars 3million serial and up? They are hourglass shaped. f/1.5 and f/2 variants. If you thought the wartime LTM Sonnar helical construction was so-so (I agree!) you should see these. The focus helical is literally just two aluminum pieces with a helical groove in which a big screw rides. That's the ..er .. focus mount.
Optically they are amazing, with a different design objective than the wartime Sonnars I would guess. (The post war Jena formulation, which apparently is a dead end on the family-tree as the Russians [post ZK which seem to reference the 3mil designs] went back to the pre-war designs. I think.) They lose to their wartime brethren wide-open due to more spherical aberration, but get insanely sharp across the entire frame by ~f/2.8 onward with reduced vignette, as well.
I also have click stop (yes really) Sonnars, Brass focus mounts, X-Ray mounts and some other oddities. We should definitely compare notes once we have some extra time!
I went back to the Jupiter a fourth time and I think this is as good as it's going to get for me.
Since these pictures were taken I've sanded the rear element mount down a tiny bit more in hope to bring close focus a bit further towards the front (meaning towards the camera) without disturbing the overall calibration I've achieved.
I've managed to mitigate the worst of the shift except for the very closest distance which in practical terms I almost never use anyway. I've done some additional filing but I doubt it will move the needle much. All of the crops below are 100% views from scans using 100 speed Film.
Oh and before I forget, I also have a theory question:
I understand how the formula works for shortening the lens focal length, but why does the main-shim have to be increased?
Usually the shorter the focal length the less the displacement of the lens-body from its infinity location. So, following that logic one would expect the main shim to require reduction, not a padding out, as increasing the main-shim moves the focus closer towards the camera. And shortening the focal length should have the same effect.
However, in practice it turned out that yes the main shim has to be increased slightly. So Brians instructions are absolutely correct; however I want to understand the theory behind it better.
I am really impressed with the work you have done on this lens, looks like it is performing pretty well, a big improvement from starting point
Thank you. I actually am surprised myself.
I originally just bought this J3 because it had a nice focus mount and I wanted to re-mount one of my LTM wartime Sonnars into it. Now I will however keep the Jupiter-3 in there.
