monkeyfist
Hello There,
i have two questions.
I successfully installed Color Trio on my G4 PowerMac to get my 11000 to work. Thank´s to the downloads from jzagaja on these blog.
I scan my negatives to raw 16bit and then convert them to positives with ColorNeg.
Have anyone experience with ColorQuartet?
Do you think i would get better results if i do the conversion with CQ?
Second question is, the door lid of the scanner don´t move up automatically. I can hear the motor but nothing moves. I have to open it manually.
Are there any repair manuals or something like this available.
How does the mechanism work.
Thanks in advance
you can actually do a white calibration on the orange mask of the negative, it usually says "white calibration failed", but it still works. Dont know why it says so, but this way the orange mask is eliminated straight in the scanning phase. Also gives a better file with more information. As the white point is closer to where it should be.
If this does not work, just do the conversion manually in PS. Its easy, and you are in control instead of all these automated plugins etc.
