Pali, You just prove, that Raw file need little bit more tweaking in film profile in Color Perfect. As You now, every developed c41 film can have some differences in color mask and overall color balance, the developing procedure is hard to get every time the same colors. Whats why film profiles in Color Perfect or Silverfast are only starting point for more tweaking. From that point, there is no sens for it8 calibration for scanning color negatives, because You will correct color cast in film profile, even if scanner don't have perfect color reproduction. This is way how work scanning procedure whit Silverfast or ColorPerfect. Just read tutorial for this software.
Inverting color negatives are always subjective manner and that is why it is so difficult to achieve good results.
I may add that both of your examples, you can see a problem with the gamut of colors. Instead of red, both have something closer to pink. This can be seen both on the car in the upper left corner, as well as on the printing parameters exposure on the edge of the film. It is a mistake to assign the wrong profile colors at work and presentation on the Web.
Monkeyfist, my dear friend. I think that you're trying to be smarter, from the people who created the software that you were using. So again, for the explanation:
http://www.c-f-systems.com/ColorNegativeFAQ.html#tricky
http://www.c-f-systems.com/ColorNegativeFAQ.html#CM
IT8 profiling and gamut of colors, are two different things. The best method of working with scans, scans RAW without IT8 profile, with Hardware gamut scanner. Based on a scan of RAW, you can calibrate the scanner using the IT8 target and external calibration program (eg. CoCa) and use the created calibration file at any time. So, no matter whether you scan a slide or negative, throwing the scan to Photoshop (or another program), you can define yourself, if you want to use the calibration file or not. At the same time you can choose a color profile color (gamut) in which you want to work (sRGB, Adobe RGB, etc ...)
I had to replace one of the internal fans on my SM 11000 recently. I am also speculating that this fan caused some power issues that I reported about my unit a few months ago.
It all started when my scanner started making abnormal humming noise and upon inspection I found that one of the fans behind the lamp assembly was the culprit. I tried cleaning it but it seemed that the internal bearings had gone past their life and I needed to replace the fan.
I tried to look up for the same FAN but did not find any for sale that were new. I then matched the rating of the fan (speed, voltage, fan setup, dimensions) to the exact replacement that is easily available on Amazon and other common sources. The replacement was very easy and the fan is working perfectly.
Here is a link if anyone else needs this in the future.
https://www.amazon.com/gp/product/B01FBPQMC8/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
DC Fan 60mm x 60mm x 15mm 12V Quiet Output 6015
Product Dimensions 3 x 2 x 2 inches
ASIN B01FBPQMC8
Item model number DC6015S12L
Allow me to suggest to look also at the current. It's important in getting an idea of the air flow.
Thank you. Do you mind explaining this more because I am not sure if I follow what this really means?
Pali
Sure. Two fans can have the same dimensions and operate with the same voltage. However one can have a more powerful motor inside or just higher rpms. So make sure the new one is operating within 20% of the mA of the old one.
Glad to know you are keeping an ear on the fans. Many owners think it's only a matter of noise.
Thank you again. The original has 1.9W on it while the spec sheet for the one I bought says that it is rated current is .18.
Link to the spec sheet of the replacement that I bought.
Do you think this is OK? Is there a way to measure it and if so, wouldn't the bad motor draw more than the current that it should which is the problem that I wanted to fix to begin with?
Pali
Remember Power=Voltage*Current , so Current=Power/Voltage=1.9/12 =0.158, so aprox. 0.16mA. That's close enough to 0.18. You should be fine.
Thank you so much. You are such a treasure for users of these scanners Armando!
Regards, Pali
Maybe someone can help me. I've been running Colorquartet V5.2 on a XP PC for a number of year but the computer is giving me problems so I thought I would upgrade the motherboard. The problem is new motherboards do not have parallel connectors so how and where do I connect the the parallel dongle?
Thanks,
Gale
Scanmates 11000 uses R1617 SEL2 - selected tube. Standard tube cost 468 eur in Germany. Could you please check tubes in Scanmate 5000? Selection means dark current and gain. Hamamatsu don't want sell selected tubes.
How long do PMTs last? Is the life expectancy based on age, use, or both?
One of scanners has manual gains set very high and I know it came from a news printing factory so must have been used non stop. The other came from a photographer who used it for his personal work since he bought it new in 97. The photographer machine calibrates white at minimum voltage gains across all pmt channels.
Since this machine is almost 20 years old and still balances at low gain, my guess is that it will last at least another 20 years. Does anyone generally what to expect from these?
Pali
