Thanks a lot for now to the forum and especially to you, tsiklonaut, for helping me to get this far!
Followed your suggestions and activated Apple Talk.
Restarted.
No changes there.
Plugged in another SCSI card, a Formac Pro RAID.
And . . . the scanner now is correctly identified by SCSI probe as a Scanmate Plus.
Started CQ Scan - the scanner was recognized correctly.
But the scanner still does 't show up in Apple System Profiler.
Started CQ.
Tries to telephone, but the Mac is not attached to the web.
After that, all modules in CQ are grayed out.
Then I tried to run Drum Clean in CQ Scan.
Well, the scanner reacts with some sort of sound.
The drum moves just about a few milimeters to the right and back again.
The red LED ("operating") is blinking ever since in very short intervalls.
But the drum does nothing at all.
Nor can I see anything processing/progressing in the CQ Scan software.
I definetly need a manual to operate the scanner, because I 've got absolutely no idea how to scan a negative 😡
But at least the SCSI problem is solved and the scanner is being recognized by the software.
That 's a start!🙂
Hey, hey - wait a minute . . .
I 've somehow managed to get CQ working.
In the Connections window there are four symbols, connection symbols.
They all look alike, except for the one in the upper left corner, which is darkened.
So I just clicked on the symbol next to it in the upper right corner.
And, beleive it or not, after trying to telephone once more, it works!!!
Hurray!!!!!!
No all I need to know is how to operate the system . . .
And if there is now manual to give me advice, then all that 's left is gonna be: trial and error.
I don 't know how long it 's gonna taken me to get the first results.
But now that I 've come that far, I 'll keep on trying further on . . .
Patrick
I upgraded to Scanmate 11000, and got a Scanflow Mounter with it.
Any experience with this machine?
Hello Everyone!
I've just purchased a SM5000 days ago and it should arrive sometime today. I'm still slightly confused in regards to finding the right compatible computer to run the scanner. I see that the Mac G4 is the best bet but is there anything I should for while finding a G4? This is my first time getting into drum scanner.
monkeyfist - what aperture are you using? Is it apples to apples between the two?
I have been using auto aperture, so i assume it's aperture 1. If i choose aperture 2, the result is clearly softer image.
I'm not even sure is 1 larger aperture and 6 smaller, or the other way around.
QC manual speaks about the aperture function as a way to soften, or defocus the image.
The difference between SM5000 and SM11000 seems to be small, and it does make senses as the optical assembly is so identical. But I did get slightly sharper scan from SM11000. Check the picture i posted, you need to open them as full size to see them properly.
There is also the 12bit vs 14bit difference, though i don't think it matters much.
All in all, i could have lived with SM5000 easily. Both of these machines are great.
But hey, SM11000 has this super cool motorized drum cover. I could play with it all day long.
I have the SM11000 and I have some B&W that I need to scan. I'll scan a 11000 DPI for you. For my own scans, the most I go is about 4000 for medium format. For large format (4x5) - the buffer maxes out 2100 DPI and 1100 for 8x10 🙂 so yes, I too could have done with just SM5000.
That would be good, so my OCD scanner mind could be at ease... if you can, just scan 100% grain samples at 5000dpi & 11000dpi. Preferably in the RAW mode.. as it seems to make a pretty big difference.
I kinda got this SM11000 thinkin it could do 11000dpi grain sharp scans, or at least 6300dpi scans that would be as sharp as Flextights. I don't shoot much 35mm, but i like to print them pretty large.
