Scanner Newbie Query
1750Shooter
12:35 AM
I've decided to think about a scanner & it seems as though the V700 fits my needs (primarily 2 1/4 with some 4x5). My only question is - does the scanner software comvert negatives to positives during the scan so I can see them on screen as they will print or will I have to try to play with a negative? Thanks for any help.
You will definitely need to calibrate your monitor if you want any hope of WYSIWYG. Custom printer profiles help too. With that said, there is a good chance you will always need to do some fine tweaking of your scanned files before you print them. The "just push a button and get perfect results" promoted by scanner makers is pretty much a myth. Be prepared to learn some new skills and spend time prepping your images before printing.
Doug
