Scanner Recommendations for Panoramic 35mm Images
jseakoi
2:35 PM
Ive been going to Walgreens to have my film feveloped and then scanned onto a CD for around $11. But havent been satsified with the low resolution that they scan. Looks good when small but horrible when blown up.
I've been contemplating getting a hi-res scanner and scanning my negatives myself. Recently I got a used Horizon Perfekt panoramic camera and it turns out that Walgreen's equipment won't scan this film properly (it crops the image to a standard size).
Any affordable hi res scanner recommendations that will be able to scan these images? Affordable for me means around $100 or less.
Thanks!
Sub $100 & hi-res?! Erm, no.
Either you settle for a 1500dpi resolution of a flatbed or buy a proper 35mm film scanner and scan Horizon 58x24 frame in two takes and then stitch them together.
In terms of the budget, I'm talking about getting a used scanner (Criagslist / eBay / etc). So...I guess the budget would be more like $200 or so.
how about using your budget to get a macro lens for your digital camera? then take two photos of each panorama shot and stitch them. with care, the results should be pretty good. there are numerous how-to articles out there.
good luck
rick
What frame size?
Is it true panoramic, or cropped 24x36?
IIRC, many dedicated 35mm scanners wont do panoramic (24x50+) images.
I've been scanning my 24x54 panoramic images with an Epson V500, and does great for my needs. It should provide results that far exceed the Wal-Mart scans.
