scanning for web-viewing: tiffs vs jpegs/ 8 vs 16 bit
msbarnes
4:08 PM
NY, NY
I normally scan my negatives 2400 dpi / tiffs / and 16-bit grayscale. (V750) And then I tweak it in photoshop (usually just levels/curves) and then I save the jpeg.
Now I only use these images for web viewing but is this "overkill"? Would I be just as well off saving it as jpegs/8-bit to save time/space? I never mind so much because I just figured that more information is better and this seems to be a good threshold for what is somewhat manageable.
you're right, 16bit tiff is too much for web-viewing. nowadays, my scan workflow is like this: i scan the whole roll to small size jpgs, normaly 2000dpi that is more than enough for posting online. if some photos are worth to keep then i re-scan them 16bit tiff @2700 dpi (max res of my Nikon CSIV)
I scan everything as a 16 bit TIFF just because most film scans need editing to make them have the right tonality and color (for color photos). 16 bit TIFFs stand up to tonal manipulation a lot better than JPEG, so scan as 16 bit TIFF, edit, then save as an 8bit JPEG for best quality web image.
If you are tying to save disk space or give your processor a break, I would reduce resolution before reducing bit depth. At a lower resolution, you will still be getting the advantages of better latitude and tonality.
I sometimes batch scan images at a lower resolution as 16bit DNG, and then tweak them in Lightroom. If I later decide to rescan some of the images I just apply the same settings in LR. That gives me at least a great starting point, and sometimes that is all they need.
thanks for the responses: very informative and to the point.
I just wanted to be consistent and structure my workflow so that it is efficient. It sounds like what I am doing is probably fine and not really overkill.
Storage is cheap. Digitally, I shoot RAW, so I also scan 16 bit TIFFs, adjust in Lightroom and if something wants to published to web, export as JPG.
