johannielscom
Snorting silver salts
Late to the party but I'll chime in, for what it's still worth.
On site:
Developing:
Scanning:
Admittedly, the above approach gets me good images on medium format and bigger, but it should do the trick on 135 format too.
Rodinal was conceived in a time when stand development was the only way to develop so don't buy into the 'uneven development' story. Century-old plates don't all show uneven development and streaking etc. Trick is to keep the reaction down by keeping it cold and you'll be fine.
No matter what film and developing approach, use filters! I'm suprised nobody recommended using those, no landscape photographer should go without them imho.
Graduated filters are readily available and if you use the Cokin system, you can simply use the filters on multiple lenses if you only change the ring on the filter holder.
Using Fomapan and X-Tol is a very good alternative combo, quicker to use and no hour-long fridge hassle either.
Happy shooting!
On site:
- Expose the film half the box speed.
- Meter for the darkest part you still want detail in.
- To check exposure range, also meter for the brightest part, ususally the sky in landscapes: if there's more than 4 stops difference you either need a graduated filter, or return when the light is less bright...
Developing:
- Use Rodinal 1:100 stand development in the fridge: just use tap water, shake vigorously for 1 minute, leave alone in the fridge for 59 minutes.
Make sure to fix with fresh fixer
Scanning:
- Use the flat VueScan file, no corrections there
- Use 16-bit software, I can really recommend Lightroom and you can try it for free for a month
- Adjust the curves to get decent mid-tones, not the contrast since that will get you darker and lighter but leave the mid-tones flat
Happy shooting!
