SDHC cards
Yes, I ordered a second 8GB Sandisk Ultra II Plus USB (it has a built-in USB connector). I tested the M8 firmware 2.0 with the 8GB card I keep in my DP1, and it seems to work fine.
NewEgg
NewEgg
Ordered two 16GB from them last night. Should be here tomorrow. I got the RiDATA Lightning 16GB Secure Digital Class 6 High-Capacity for only $42 each. If the M8 can't use them, I know my D-LUX 3 will.
Can someone do the following test of an SDHC card?
My Transcend 4GB 150x SD card and my 1GB Sandisk II, takes 46 seconds to do the following:
From a freshly formatted card, turn on continuous exposure, start your timer when you press the shutter, count 20 shutter actuations, release the shutter on the 20th shutter actuation, stop timer when red flashing "writing" LED goes off on on the back of the camera?
This will give an idea of SDHC performance over/under these two cards.
Thanks, Robert
Thanks, Robert
that sounds like a good test.
Are SDHC cards marketed as faster? or just more memory?
The best deal I found on the net today is this:
A-DATA 16GB Turbo 150X Secure Digital High Capacity (SDHC) Class 6 Memory Card - Retail Package » for $36.39 at SuperMediaStore.com
At Checkout apply 30% off Special Coupon Code: SUPER30 (Exp. 09/21/2008)
Final Price: $51.99 - 30% = $36.39 + Free Shipping + No Tax (Except CA)
It is Class 6 which means 150x speed, 16GB SDHC for $36.39 Free Shipping - Not a bad deal~
Thanks, Robert
Borrowed an 8GB Kodak SDHC card, and attempted your test. Got to 10 exposures, and shutter acuations stopped, and the message "Data Transfer" appeared on the screen. That was at 35 sec. I stopped there, and it took about 2.5 minutes for the red LED to stop flashing! :mad:
so as I understand it now, a bog standard card, although SDHC, is not fast per se. The "Kodak" SDHC card was painfully slow in testing. I have ordered a couple of the 8GB Sandisk Extreme III cards. They should cover all my shooting needs (i.e. 500+ images per card!) [Raw+jpeg fine] Does anyone remember the "bad old days" of 36 shots per roll of film!! :D
Thanks for all the replies, much appreciated :)
so in the 42 second test, how long does it take for the buffer to clear?
I run into this problem all the time shooting music, its extremely annoying, sometimes i just pop out the battery and reset the thing, i loose alot of shots, but id rather have an opportunity to make more.
can you suggest the best card for music? i.e. best performance?
thanks
Camera and A Data 16mp showed up, counter went to 999 for raw + fine jpeg, still there, and looks like 43 seconds for ten Raw + fine jpeg. It did stop to write after ten, am not sure if everyone is doing Raw + jpeg?
Extreme II card was a few seconds faster.
Regards, John
I can report that the 8GB PNY cards sold at Best Buy for $35 work perfectly. 757 DNG's per card!
well guess what I'm going to go nab this weekend....with that much storage though i'm gonna have to make sure I clean up my hard drive to make room for importing them all haha.
I bought a 8 Gig card - totally useless probably as I hardly shoot 700+ pictures with the same card, but I feel well prepared for the next firmware upgrade allowing MP3/4 playback :D
