Seeeeeeeeeeearch!!
rxmd
May contain traces of nut
7:49 AM
Kyrgyzstan
maybe I'm just dense but I think the search function on the site is completely broken.
- There is no way to search for two keywords in the same post. If I want to search for "MP finder upgrade", I get all posts containing "MP" or "finder" OR "upgrade", which is obviously useless. Or try looking for posts about a "quick load kit" one day. Same if I want to look for all posts containing both "Canon" and "Leica" - no Boolean operators ("AND", "OR", "NOT") either.
- The search index only goes back a few months. Older discussions are inaccessible. The same topics are bound to crop up again and again. This is especially bad because the forums are being reorganised constantly at the moment, meaning if you have a problem with the Hexar, for example you don't really know where to look - Hexar RF forum? Konica RF forum? Leica M forum? Having a good search function is essential.
At present I can really only recommend searching the site using Google with "site:rangefinderforum.com". This is obviously a kludge but it's the only way to get marginally more useful search results. Is this really meant to be that way with the board software or is it just the way it's configured on RFF?
Philipp
I find the dropdown "Search" to be a little wishwashy, but the "Advance Search" seems to work well. If in doubt, I just use google.
Type in:
site:rangefinderforum.com {search string(s)}
ie:
site:rangefinderforum.com leica m3
and off you go.
Suggestion
Suggestion
OK. If this is the case, then here is a suggestion for an improvement to the site that should require very little work and increase functionality quite a bit:
If Stephen officially acknowledges that Google is a better way to search the site, then add a Google search box to the site somewhere. Here's how this can be done:
This would make search easier for a lot of people, and in addition it would decrease server load. If I remember correctly Google also pays ad revenue for the text ads it places next to the results, so it would also help pay for the site.
Philipp
