Godfrey
somewhat colored
heh! That's funny. 🙂Your car's stance makes it look like the 'fanalone' cause the front end to dip.
Over the course of the past few years, I did some things to improve the front end feel and handling. The Fulvia front end was designed around the highly crowned, secondary roads of its time, with 14x4" rims and skinny 135mm tires running +2° static camber. With more modern 14x6 wheels and 175/70 tires (per the later series of the same car) on USA freeways (which are flat and smooth), that original geometry is a handicap as it actually lifts the tread off the road on hard cornering.
So, to get the geometry into the right ballpark, I first fitted 20mm shorter spring blocks on the front spring, which has the effect of lifting the suspension arms just a little and reducing the camber. I then fitted a set of customized lower control arms that are a few mm longer than stock, which again reduces camber a touch. Static camber with this setup is now running between 0° and -0.5°; front end feel is greatly improved and cornering traction is improved by quite a bit, and the car has a nicely "hunkered down at the front" look... which you can see from this side view:
It's not too radical, and of course the angle that you shoot from can exaggerate it easily. 🙂
(Some have asked my why I didn't lower the rear ride height as well, but there's no advantage to that with the beam axle at the rear; for road use, all you're doing then is making the suspension harsher and less compliant.)
G
