S
Sean Reid
Guest
I'd love to hear from other R-D1 owners about the following:
From time to time (much more often recently) I've found that my shutter release will not trip the shutter even after the advance has been fully cocked. Until today, when this had happened I had been, out of film camera habit, moving the advance lever through its arc a second time. That always seemed to fix the problem (an illusion and coincidence, I now think). Today I discovered a pattern that seemed to point to a problem unrelated to the shutter cocking lever.
The problem does not ever seem to occur when the LCD is folded in (unless the battery is near dead but I'll ignore that exception for obvious reasons). If the LCD is folded out, this problem will sometimes occur even if that LCD is turned off. I discovered today that the solution is to simply release the shutter and press it again (even if the LCD has been off for some time prior to the first shutter press).
First, I think Epson should modify the camera (by firmware if possible) so that a single press of the shutter release not only turns off the LCD (when its on) but also releases the shutter. This is the norm on DSLRs and there's no good reason for needing a double press. It seems to me that my unit is sometimes sending an "LCD on" message to the brain unit responsible for the shutter release *even when the LCD is off*. A loose wire? A bad connection? Dunno yet. Before I bring this problem to Epson I wanted to find out who else (if anyone) is experiencing it.
If you own an R-D1 and can spare a free moment, would you please test your camera to see if it displays this behavior. A friend of mine is currently testing a review unit from Epson and that unit seems to be behaving similarly. I suspect that there could be something amiss in the wires that go from the moveable LCD unit to the body. Might they be fragile?
Along with your response, please indicate approx. serial number and approx. number of exposures made by the camera so far.
Thanks,
Sean
Thanks,
Sean
