S
Sean Reid
Guest
Charles D. Orze said:Hi Sean,
Thanks for the reviews on Luminous Landscape.
You're welcome, glad that you enjoyed them.
Sean
Gid said:Hi Sean,
There was a post on this somewhere else - may have been dpreveiw epson forum. However, here's the thing. If you've reveiwed an image on the LCD and dont switch off the LCD using the menu button, then, what you describe happens consistently i.e. double shutter press required. Switch off the LCD using the menu button and always a single shutter press. Since I picked this up, I have had no problems when I follow this procedure. However, I do still forget and when I do, guess what - two presses required. It should be fixed so that this doesn't happen, but there's the workaround. Hope this helps.
Regards
Gid
