shutter speeds off for Widelux?
jvan01
8:34 AM
My Widelux F7 seems to have slow shutter times:
at 1/15 sec, the full swing of the lens takes about 6 seconds
at 1/125, the full swing takes about 0.7 seconds
at 1/250, the full swings takes about 0.3 seconds
Are these times offbase here?
I think that sounds about right.
1/60 should be about 1.4 sec
1/30 roughly 3
1/15 roughly 6
- it has to get the exposure across the entire area, and they are moving in the standard progression (doubling)... so I'd guess they are about right.
1/30 roughly 3
1/15 roughly 6
The speeds seem to be proportionally correct relative to each other, yes. But it seems that all speeds are slow relative to Widelux spec. According to my calculations:
total duration of lens travel divided by 30 = actual shutter speed
so the real-world speeds that my Widelux gets are ~ 1/5, 1/50, and 1/100 sec, which is about 1.5 stops overexposure. This is fine for print film, but I like shooting slide film panoramas so exposure is a bit more critical for my purposes.
Hmm, time to do more tests....my guess is that the camera needs a CLA. Also noticed that speeds run slower in cold weather.
If anyone with Widelux and a stopwatch can do an informal test and post them here, I'd really appreciate it!
I see your post is old but i was searching info on Wideluxs and came across this. I just got a F6B today and my speed sound slow and are similar to yours w/ a stopwatch .7 sec @ 125. How did your test turn out. Did you ever get it adjusted? Will test mine with film tomorrow. Ken
