GaryLH
It looks pretty good for the price IMO and probably worth a try ... if it doesn't work out I'll give you fifty dollars for it! 😀
Composing with an LCD on a camera with this focal length is a recipe for disaster in poor light IMO and I use an accessory viewfinder so I can brace the camera against my head in situations where hand held is the only option. The finder I use is one of the old variable Leitz type that has parralax adjustment so I can get the framing extremely accurate with practise.
I have the overpowering desire to get out and use the DP3M today and it's raining cats and dogs! 😛
I would tend to agree that a camera w/o any stabilization, the longer the focal length, u need to either use a ovf to create a better three point hold or maybe even something like a hoodman... I think Jon was going to investigate this. I tend to go ovf approach just because it is smaller, but a hoodman can also provide a more accurate picture plus the three point brace. When u add the extra weight from a grip setup like rrs, it all helps.
I think the dp2m is the longest les u can get away w/ using the LCD handheld.
I tend to go a min. Of 2x the efov for the shutter speed. Since the efov in this case is a 75.. That would mean min. Of 150th. So I would use 250 as much as possible until I was forced down to 125th or 60th.
Gary
