ped
Small brown dog
Hi guys
Just bought one of these on ebay.
Does anyone know if there's a leica square hood that'll fit the lens, as opposed to the vented round hood?
I'm sure I've seen a picture of one before.
I much prefer the look of square hoods, that' all...
Cheers
ped
This is my version, by the way - is this a 'Type 2'?
Cheers
ped
markrich
Enthusiatic amatuer
If this is a the same screw fit version I bought on eBay it will look great on the lens but will cause vignetting on every corner of the photos. I had to crop all my images on the computer post scan, which took a while when you have 6 rolls of 36 images each! :-(
furbs
Are you using the LH-4 hood? That seems to be the one designed for the Color Skopar...
zuiko85
I have one of those Voightlander LH-4 hoods for my 35 PII but don't use it. Too bulky. Instead I bought a 39mm short hood with 46mm front cap from e-bay seller Heavystar. It fits perfect, does not vignette the corners and makes a tidy package. The LH-4 came with the lens when I bought it used.
ped
Small brown dog
Thanks guys I'm assuming the LH-4 won't vignette as it was designed for the lens (or vice versa) but really wanted to know if the bayonet fit of the hood was a VC special or if it was compatible with any other square shades.
Cheers
Cheers
markrich
Enthusiatic amatuer
The Voigtlander lens hood clips on the lens. The Chinese copy I bought, which looks like the image, screws on and when used with the lens filter just gets in the way by a fraction.
Still, it looks cool on the lens
ped
Small brown dog
Yep cheers, the one supplied is an LH-4.
Any ideas RE my original question?
Cheers
Cheers
markrich
Enthusiatic amatuer
There is an ad here for a square hood for the 35mm f/1.4. It's possible the seller may have something similar for your lens.
http://www.shapeways.com/model/154600/voigtlander-nokton-35mm-1-4-lens-hood-v5.html
cz23
Maybe email Stephen? If anyone would know, he would.
John
John
ped
Small brown dog
Interesting, thanks for that!
