Slide at 400 ASA
caila77
2:02 PM
Italy
I love to use slide film and I’d like to know which slide do you use at 400 ASA?
Someone use only slide 100 or 200 ISO pushing it at 400 ISO
Some comments will be accepted
regards
Some comments . . . . I have one : If you want a 400 ASA slide film, why not try Provia? Nothing tricky about it, seeing as it is 400 ASA naturally.
What kind of camera and lens are you using? What is the maximum apperture of the lens? What type of shooting are you doing? Is it all low light, or something where you need speed to stop the action?
Tom
Hi Tom, Generaally I use some different cameras in 24x36 format (bessa R, Bessa T, Canon P, Nikon f801s and Nikon FE). I use generally 35mm (max f 2.5/2.8) and 24mm (f2.8) (sometimes 50mm) and I need slide for landscape and building in low light (I don't need slide for stop the action). I'd like to use it when I travel in a different town!
thank you
Tom
I'll try
I'll try
Ok, I'll try it but it quite expensive here in italy.
many comments about this slide?
