So I shot up this roll of Ilford XP1 400
Pirate
Guitar playing Fotografer
11:48 AM
Highland, Mi.
...and now find out it hasn't been made in a while.
I have two rolls in the fridge along with some colour stuff.
So, there's no chance of me developing this XP1 here at home, is there? I don't have C-41 stuff, just Black and White Negative chemicals.
I want what is on this roll, it's not for experimenting.
P^)
C41 is the same process as color film, so you can drop the film at any shop that process color film.
Don't forget you can process C41 with traditional B&W chemicals. With colour film you end up with a grainy B&W image; with a C41 B&W film you'd get a B&W image just like normal, but made from grains instead of dye.
The nice thing about C41 is because it's a `standard' process (unlike traditional B&W), the times for using traditional developers with C41 are identical for all C41 films.
Not really something you'd do for amazing image quality, but something fun to try.
I wish I could get C41 kits here in NZ.
While XP-2 calls for a standard C-41 processing, XP-1 comes out a bit flat if taken to the local lab. Ilford's XP-1 processing kit, apparently a slightly non-standard variation of C-41, perks up the contrast to a more normal level.
I kept a dozen or so rolls of hand-loaded XP-1 in the fridge for a bit over 20 years before using them. They were fine, still a bit flat in standard C-41, and my cooperative local lab gave most of the rolls about a 1/2-stop "push" processing that worked well, as I found their 1-stop push blew out highlights too readily.
Pirate, you should be fine with the C-41 kit from Freestyle, especially if you extend the developer step by 15-20 seconds.
Does this mean I'd get smoother results if I processed standard B&W film in C41 chemicals, and less grain?
No. The dye precursors are in the film.
From the other direction, the few results I've seen of XP-series in B+W devs tend to have good highlights and mid-tones and blocked-up shadows.
As the newest XP1 expired well over a decade ago, you may find the stuff you have to be a bit foggy.
The image would still be made up of grains, because as Mr Hicks says the dyes that the C41 process activates aren't present in normal B&W film. So it wouldn't look smooth.
But I think it would be possible to get something printable -- I see on the Massive Dev Chart there's some times for Technical Pan in C41 dev. They say to use B&W fix (which is interesting, there's some folks on APUG who buy C41 colour fix to fix their B&W because it's cheaper in bulk), and obviously not to bleach, as there won't be anything left 😱
