qruyk12
WHat do you all think? Soft release a good idea?
Damaso
Photojournalist
Yes, it is a great idea and I speak form experience!
peterm1
I have a soft release on my M3. The biggest issue first - it looks cool!
But I have to admit it works for me. It does allow you to position your index finger better.
Go for it!
Go for it!
photo4ls
You could do a search since there is
a thread about this from some time
back. You will find quite a few opinions,
but most people here seem to like them
if I remember correctly.
photo4ls
wontonny
It has it's ups and downs.
It does make the button easier to press, especially when doing a button down vertical shot. But therein lies a problem. It goes off in your bag easily, and if you have a battery operated M meter, it'll depress the button in your bag without your knowledge and drain your battery completely.
letvet
Keep your money. Although, you do get the occasional cool "off the hip" shot.
Al Kaplan
NO NO NO. Learn to arch your finger and practice moving just the tip of your finger straight up and down without moving any other muscle in your hand. You don't even need a camera to practice the motion.
BillBingham2
Registered User
I love them but not the same on every camera. I used MSRs on every Bessa, LOVE THEM! Tom A ROCKS. On my Ms I used Nikon AR-9s. They just felt good. An AR-1 is on my S3 and was on my S2. Each has a different feel, just like cameras. You need to find yourself what works for you and your camera. They are very low cost so try two different ones and see what works best for you.
B2 (;->
B2 (;->
jmcd
I bought a quick release and tried it, but personally I prefer the "arched finger" approach described by Al Kaplan.
ali_baba
i have tried them but as i keep my camera(s) over my shoulder(s) i found they fire off too many shots.
al/bill -- care to show a photo of this that you speak of?
i'm having a hard time visualizing...although i probably do this already...
Soft release or not?
Not for me... But I don't usually share that opinion as it doesn't contribute anything positive to the discussion. Maybe there are others who do the same, skewing the apparent consensus.
I also don't care for the Thumbs Up or soft cases, but do like accessory grips.
Roger Hicks
I also don't care for the Thumbs Up or soft cases, but do like accessory grips.![]()
Dear Doug,
As you point out, saying you don't like something can be useful if it shows people that enthusiastic reviews are not the only possibility. Some love 'em; I hate 'em.
Personally I dislike anything that makes the camera bulkier, except Leicavits/Rapidwinds, but I particularly dislike soft releases because they put the release in the 'wrong' place. After 35 years using M-series Leicas my finger 'knows' where the release is supposed to be, to the millimetre.
Somewhere I've even got the Leica adapter-cum-soft-release for using screw-mount cable releases (cup-type) on M-series Leicas (PC taper type).
Tashi delek,
Pablito
coco frío
YES YES YES. NO NO NO.
why not just try for yourself? They are cheap enough.
I generally dislike accessories, but these things are brilliant, they work for me anyway.
Nugard
Elvis lives!..
Cheap enough?......
Hahaha... Good for you...
Personally I hate them... I don't like the look... And I really like the original release... And also I don't think it's cheap...
Why not putting this thread as a vote?..
250swb
I made my own and it worked great, a very nice feel to the pressure on the shutter button, and it smooths the firing action and reduces any jolts at long shutter speeds. Then I discovered the downside of it firing the shutter every time the camera was put in the bag, and the battery draining, and now it is redundant.
Steve
Steve
George Bonanno
Al Kaplan's approach is the proper way to take a snapshots... heed his advice.
Camera enthusiasts are focused on form and feel moreover than viewfinder activity (subject matter).
It's very basic for a photographer to adapt however an enthusiast is doomed to equipment dissatisfaction.
Pablito
coco frío
Cheap enough?......
The look? Well, I could care less what the camera looks like (if that is what you mean), but it works for me. (Been using Leica M cameras as long as Roger...)
They cost $15 dollars US, more or less...
Put it to a vote and you'd get a statistic. Some people like e'm, some don't. That's good enough for me.
Some things you just gotta try to see if you like them. Like foods.
Wow! now there is a proper way to take a snapshot!!
George Bonanno
Dear Pablito,
Yes there is. There is the right way (proper) and there is the wrong way of taking a snapshot. You are getting off the subject here because of your pompous mindset however I will humor you.
On second thought I'm going to pass on the above. You are right and I am wrong.
Wishing you all the best with your photography,
George
George
edodo
Soft release are a good idea for your index pleasure and for longer shutter times. It is also very good at shooting blank frame too! I have three Tom's softies, two for the M4s, one for the rolleiflex (I cutted the softy for that!). It is also a good idea to remember wich film is in your leicas (I use red for positive and blue for black and white FYI)
