Chubberino
Hello!
After years of browsing charity shops, I finally stumbled upon a decent deal on a vintage camera!
It's a Rolleicord III. Upon first inspection the camera looked worse for wear. It smelled moldy but at the price it was offered, I opted to get it. When I brought it home, I took it out of the case and saw that white mildew had formed on the leather covering. The leather case smelled moldy as well, so that's being treated in a baking soda bath and I'm hoping for the best.
The taking lens and the viewfinder lens both appeared to have bad cases of mold, but upon cleaning the taking lens, it is actually fairly pristine. Lucky me. The mold was worse looking in the view lens but wiping it off from the front only, the mold disappeared and caused no etching so it looks like, so far, the mold wasn't intrusive.
I decided that due to the price I paid, I'm going to have a go at fixing this old Rolleicord up myself. Should be a good learning experience and at the very least something fun to test around with.
I've already removed the funky leather in anticipation of replacing it so that wasn't hard.
The design on this one obviously allows for easy access to the mirror and ground glass for a good cleaning as well.
I guess for right now, the biggest question I have is, there is somewhat of an issue with the shutter release button.
I've attached pics and I'll try to explain to the best of my ability what seems to be the issue.
Attached to the shutter release area was this little extender piece:
I didn't think anything of it as I have no experience with this version of Rollei, and only noticed it was unnatural when I tried to adjust the aperture. It got in the way of the aperture lever when trying to adjust it to wide open.
This seemed like a design flaw, so upon closer inspection, I saw that it wasn't even properly screwed in:
And of course, when I tried to screw it in, it wouldn't thread properly.
So, I think it's not designed for this version of Rollei.
But, if it isn't screwed in, then there's no way to actual fire the shutter as no button is present:
So, long story short, what part do I need for this version of a Rollei, to have a normal shutter button that doesn't interfere with the aperture lever? Or does it look like maybe the original shutter button sheared off and this was the owner's quick fix?
Thanks for your help and I'll probably update as I go with this little project camera.
