ChrisN
Striving
... to me that is. I can't find out much about this one from searching the web, so I thought I'd share it here and see if someone knows anything about it.
It's an Olympus-S. Heavy. G.Zuiko lens (7-element), 1:1.8, 42mm focal length. B, 1sec - 1/500 mechanical shutter, f1.8-16. 10-400 ASA. Manual exposure with built-in meter. The lens is clean with no fungus and just a few spots of dust.
Great case - the top part of the front of the case hinges and flips forward. Short-throw film-advance lever. There's a neat little dial in the centre of the film-advance that you can set to remind you what film is loaded - COL, PAN, EMP (what's EMP?). Depth-of-field scale. Rangefinder spot is very clear, viewfinder is parallax-corrected for close-focus, about as bright as a Yashica viewfinder (to make the rangefinder spot stand out better).
The meter needle is visible in the viewfinder (change the aperture/shutter speed to centre the needle). The meter seems to work, with a LR44 battery installed but the needle is a bit sticky; will find out more tomorrow in sunlight. The rangefinder seems to be spot-on for distance compared with the focus distance scale on the lens. The front of the viewfinder and the rangefinder windows are shaded by the black plastic housing. Strap lugs on the body and another set on the case. I really like the way you can grip and move the shutter speed and aperture selector rings together, to change the aperture/DOF without changing the exposure (ie the shutter speed moves in sync) - I haven't seen that before but I guess it's not uncommon. Light seals mostly rely on the back lid fitting into deep grooves - had to replace one section of felt light seal at the hinge. The self timer works! In fact everything on this seems to work!
I'm looking forward to running some film through this on the weekend. 😛
Can anyone tell me when these were produced, and where they fitted in the evolution of Olympus rangefinders?
Chris
Chris
