Sonnar 135mm f4-what mount?
bogdanb
10:44 AM
I picked up this Carl Zeis Jena Sonnar 135mm f4 for cheap a few days ago, but I'm having troubles determining what mount is in. It looks like a M39 and I can screw it in on a LTM camera, but it won't action the rangefinder (the inner ring that usually pushes the cam follower is too far recessed into the lens, and it won't get anywhere beyond the point where the outer threaded ring ends, as you can see in the picture below). Is it a m39 lens made for Zenit SLRs?
It definitely doesn't have the contax mount. The sn is 4905###, which puts it in the late 50's, according to the lists one can find on the internet. It doesn't look like any of the jupiter 11 variants listed here.
http://www.sovietcams.com/index.php?173991321
It actually looks very much like many 135mm f4 sonnars made for exakta, but it doesn't have a bayonet mount.
That's what crossed my mind too. Is it possible to machine down a m42 mount to a m39?
How is the aperture operated? Is it a preset lens? Does the aperture "lock" into place? Or is it a manual (aperture) lens?
By the late 50s, I don't think Zeiss was making manual diaphragm lenses for SLRs. If it has a preset diaphragm (lift and set) then it is definitely an SLR lens.
It doesn't have an aperture pin. As it is now, the only way to stop down the lens is by using its aperture ring, although there are 2 small holes at 3 and 9 o'clock that could have accommodated some sort of pin (see the photo below).
Sure that that is no internal thread, on a lens that lost its (presumably Exakta or M42) mount? One of the holes might be the counterpart to the locking screw that once secured the mount, the other could have housed the plunger for the auto aperture.
How long is the lens, at infinity?
It would not be a semi-auto lens (fully automatic diaphragm operation was not used on the aluminum barrel CZJ lenses so far as I know).
But if it is a preset lens you have to push the aperture ring in then turn it to the desired f-stop. The diaphragm operates the same as on a manual lens, but it won't stop down further than the selected f-stop. That's a preset lens.
Compare to this one that sold on ebay: http://www.ebay.com/itm/112-CARL-ZE...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
9cm, from where the filter ring starts to where the mount/"mount" ends.
Not a Exakta mount gone missing, then. My 60s "zebra" 135/4 for Exakta is 76mm from flange to front element. As the thread must end inside the flange to leave enough metal for the mount, it could only be Exakta (or M42 - the dimensions are similar) if the front element should be recessed by something upward of 15mm behind the filter ring (which would be unusual enough that you'd probably have mentioned it).
So back to start - manual aperture, body too short for rangefinders, and too long to have lost its original SLR mount. Might be missing its original rangefinder (if so, presumably Contax) mount, or could be a custom conversion to Zenit M39 (exact measures would be needed to verify that) - or some bellows/macro ring/visoflex thing, whether factory made or converted.
Could it be for one of those early Russian SLR's that used the 39mm mount size but at a different register distance. One test that could be done is to position a ground glass behind the lens and see how far from the thread seat it brings an object a couple of blocks away into focus. For LTM rangefinder it should be about 28.8mm if I remember right.
The front element is recessed by ~9mm with respect to the outer end of the filter ring.
The lens was part of a deal with an enlarger, so it might have been used at some point in time as an enlarging lens, although I fail to see the point of doing that.
yes, it is a preset lens. thank you for the explanation ;). never played with one before
Ok, that makes it a product intended for some sort of SLR use, whether for Zenit ZM39 (can't find any reference to CZJ making lenses for it, but socialism sometimes generated semi-official off-plan products), or a bellows head. Or, of course, some more severe custom modification from one of the regular GDR SLR mounts, involving a barrel replacement (or perhaps, cutting a M39 thread on top of a pre-existing M42).
I have just measured the flange distance that way and it seems to be 35mm or so, but I'm not sure how precise I was.
EDIT: remeasured it and it is more like 42mm
