Speed knob winding
Gordon Coale
6:57 PM
Whidbey Island -- north of Seattle
I've grown quite fond of knob winders. In fact, I've grown to prefer them to lever winders. Mechanically they are simpler. That is a good thing. A well adjusted and lubed knob winder doesn't take much effort. I think the biggest hurdle to using knob winders is the perceived slowness of use. A wrong perception.
I developed a techinque for speed knob winding. I put the knob in the space between my thumb and finger. (See first picture.) Pressing the knob with the side of my finger I pull the finger back. It completes the wind before it reaches the end of the finger. (See second picture.) Reach over, press the shutter, and go back to step 1. I can get off 10 exposures in about 15 seconds. This might not work with short fingers. Try it. How many shots can you get off with lever winders?
I tend to shoot, drop the camera from my eye and grab the knob with my left hand, twist it all the way round in one go, raise and shoot again. I can get off a couple of shots a second like that, but it hurts your wrist if you try to go through a whole roll that fast! 😉😉
PS I LOVE my FED 1!
Only my Fed 2 has a large enough knob and is smooth enough for that. My Leica IIIa's knob is too small for this and the other Kievs and Zorkis would tear the skin off my finger if I tried to do that.
I recall seeing, in a magazine in the early 1960s, a ratcheted thingamajig which fitted over the knob of a screw mount Leica and gave a lever advance. Must have been anchored to the body in some way. One of those miracle inventions which turned, for good reason, into nitrogen. Maybe helium.
Tear on your fingers yes, but not time, i'd say. Without gears involved, a small-diameter rewind knob works faster than a large one: you can roll it "lomger" between your two fingers if the diameter is small. That is, you can do two revolutions with small diam knob, while only one with a large one.
Does it make sense?🙂
